Paneling Repair
Paneling Repair
Help! I live in an old mobile home with paneling on the walls. There are some spots that need to be repaired, but I am unable to find replacement sheets. Can anyone help me on how to repair this?
It is doubtfull you can repair the paneling. Unless the panel is solid and the lamination is coming loose [might could be glued back] it is not repairable. As you have found out they no longer make panels with the same color and grain as what you have. You can however hide the damage. Some of the posibilities are - repanel the room, patch with different paneling and paint, install a wainscotting, etc. Hope this helps
