Best Way To Repair Sheetrock Plug
Old 11-19-05, 07:10 PM
Me & a buddy were running speaker wire thru the walls today. We cut out a couple of 2" x 3" sheetrock plugs that were between the greatroom & bathroom, but the wall apparretly had horizontal bracing between the 2 vertical studs prob for securing plumbing, making it impossible to run wire. What is the best way to resecure these 2 pieces back into the wall and be cosmetically acceptable?
Old 11-20-05, 06:51 AM
Two choices:
1 There are mesh patches you put over the hole and then mud.
2 Attach 1x2" boards through the edge of the good rock to overlap the hole to create a surface to which you can attach a piece of rock fitted to the hole, then mud.
I like option 2 because I think it leaves a flatter wall in the end.
Old 01-30-06, 07:52 AM
how do you attach the 1x2s? thanks
Old 01-30-06, 08:15 AM
Screw them through the edge of the good drywall.
Old 01-30-06, 09:52 AM
Another method is to cut a piece of rock larger than the hole. Then cut the backside slighty smaller than the hole and carefully peel away the excess rock on the perimeter. This results in extra paper that can be used similiar to drywall tape to mud the patch in place.
