Bowed Ceiling
zare6's Avatar
03-15-06, 06:31 AM   #1
Bowed Ceiling
I have stippled ceiling in my house in two bedrooms and the ceiling is bowed along the wall that seperates the room, any ideas?
zare6's Avatar
03-15-06, 07:47 AM   #2
Bowed Ceilings
My bungalow was built in 1978 the ceilings in the bedrooms are stippled, the ceiling on both sides of the wall that seperates the two rooms has a bow in it. The bow is 1 1/2" and extends for about 8' the crack that developed is 4 " from the wall on one side and 8" on the other, there are no signs of water damage. The cracks run perpendicular to the rafters. Any ideas of what is causing this?
marksr's Avatar
TN
03-15-06, 09:02 AM   #3
Welcome to the forums
Has anyone been in the attic? Sounds like maybe the nails came loose. If so you can prop the ceiling up and screw it tight.
retired painter/contractor avid DIYer
zare6's Avatar
03-15-06, 10:49 AM   #4
Posted By: marksr Welcome to the forums
I went up there and what I found was the wall is pushing up into the ceiling, I went into the crawl space and found the cinder block supports were being crushed. The foundation must of settled[we have had unusally high water table]so I will install teleposts and take the pressure off.
