Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
How to fix nail pops and "settlement" cracks
Old 03-19-06, 07:38 AM
tbird94's Avatar
What's the best way to fix nail pops and "settlement" cracks?
If I just hammer in the nail pops and spackle, will they pop again?
Old 03-19-06, 11:27 AM
W
Received 35 Upvotes on 29 Posts
Yes - If a nail has popped it's loose. Try to pull the nail and drive a dry wall screw nearby.
Old 03-19-06, 01:59 PM
tbird94's Avatar
Thanks! After patching the screw holes, is the spackle very likely to crack later?
Also, would it be good use screws on corner bead where the metal bead has popped away from the wall?
Old 03-19-06, 03:29 PM
W
The spackle shouldn't crack. As for the corner bead I usually use ring shank nails. They have a flat head and won't pull out.
Old 03-19-06, 05:10 PM
B
and for a better finish don't use spackle, use a joint/ drywall compound(easier to paint/cover)
just my input (do it everyday with these apartments, 10000 units plus).
barry
Old 03-20-06, 06:23 AM
Shakuhachi
barry
What is the difference between spackle and joint compound?
Old 03-20-06, 01:15 PM
Received 874 Upvotes on 765 Posts
Spackle is for minor repairs [has less shrinkage] and isn't workable over large areas. Joint compound can be used both for finishing and repairing drywall.
Old 03-21-06, 04:47 PM
B
thanks marksr, been trying to help a freind of mind get a web site up, so i have been a little bit slow to answer. in my expereance, you can tell when someone moves out and has tried to cover nail or screw holes with spackle and then the painter goes and paints over the wall, it stands out like a sore thumb.
i think it has something to do with the plastics in spackle, doesn't take paint well, heck i don't know, i just know that we have to sand down the spot, put a little mud on , sand, prime, and paint. ( the owners like us to keep the place looking like we would like to live there, which i, as well as the property manager, the asst. mgr. and 2 techs).
barry
Old 03-21-06, 06:19 PM
I believe the reason spackled repairs often show is because they are quick and often inadequate repairs. I doubt they would show if done correctly. I almost always use joint compound but then I never could see buying a pint of spackle when I always have a bucket [or partial] of mud on hand.
Old 03-22-06, 04:34 PM
B
yeah, just spread it, dry it, sand it, prime it and forget it.
it's also the closest material chemically to regular drywall.
barry
