patching holes on the ceiling
Received 0 Votes
Hi,
Here is my problem: I had some pot lights installed on the ceiling. The guy made the holes on the drywall a bit too big so the clips from the pot lights will show from the trim. My question is: is there any method to patch that holes to make them a bit smaller with some material strong enough so the clips will not cut in (because if we patch with compund the clips will cut it).
Thank you
Thank you
Can you get/use bigger trims? IMO that would be the easiest and best fix.
Durabond dries harder than j/c but I doubt it will make a big difference. If the cans are secured inplace patching with j/c [tape if needed] should be ok.
