Opinions of my spray texture results
n0c7's Avatar
CANADA
02-19-07, 05:25 PM   #1
My first time spray texturing a ceiling with a hopper gun. Used Pro-fin "medium" compound, water, and a cup of white primer. The grains were way smaller than I wanted, but everyone says it looks better than most popcorn ceilings. Looking for opinions/comments/feedback/etc
Two regular shots:
Close Up:
mikehammer's Avatar
CANADA
02-19-07, 05:54 PM   #2
Actually that close-up shot makes for a very cool wallpaper...Give it a try!
If you are happy with the result & your friends are giving you prop's for the job you did,then i would be satisfied.
Personally i like a fine texture.Thru experience,the Pattern Pistol(sprayer) has adjustment hole's with a rubber gasket.
Over use they tend to break-down & you could never achieve a consistent stipple pattern....Alway's important to mix to just the right consistency.
Another reason for a poor popcorn looking ceiling is weak pressure in the compressor.
Not too watery,not too thick.
Enjoy the room.
n0c7's Avatar
CANADA
02-19-07, 06:40 PM   #3
Thanks mikehammer. In your opinion, does this look like what a normal thin spray would look like, or amateurish?
mikehammer's Avatar
CANADA
02-19-07, 08:17 PM   #4
Very similar to what you'd find in most home's..
Whatever suit's your preference.
Builder's would prefer that thicker look in order to cover up most of their mistake's anyhow....Tapers can avoid that 3rd coat! ,)
