Help me!
Now that I have your attention, I need help. I was trying to put up a toilet paper holder in the bathroom. Drilled holes, put anchors in. Went to screw in the screws and the anchors fell through the wall. Managed to get anchors with screws attached out of the wall, but I need the anchors off so I can try something else. Anyone? It's 8:36 and I would like to finish this project before I go to bed.
Welcome to the diy forums!
If you wish/need to use the same holes it would be best to use a toggle bolt. If you can place it in a different spot [an inch or two away is ok] you can patch/fill the holes and carefully make new ones of the right size.
