repairing drywall
flirty1's Avatar
MI
08-16-07, 09:49 PM   #1
repairing drywall
how do I repair this
http://img126.imageshack.us/img126/4707/dcp1658km0.jpg
http://img126.imageshack.us/img126/1379/dcp1657pg8.jpg
http://img126.imageshack.us/img126/9071/dcp1656fp3.jpg
would using plaster work or do I need to put a patch. the furnace is right behind that wall
marksr's Avatar
TN
08-17-07, 05:01 AM   #2
It would be best to cut out the damaged portion and insert a new piece of drywall, tape and finish. The easiest way to replace a portion is to cut it out to the studs on each side, nail in a new 2x to the studs and attach the patch to it. You can also screw in a piece of wood above the cut out leaving 1/2 of it below where the 2 pieces of drywall meet to further secure the patch.
retired painter/contractor avid DIYer
flirty1's Avatar
MI
08-17-07, 05:47 PM   #3
would Gypsum Board be OK.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100322690
marksr's Avatar
TN
08-18-07, 04:44 AM   #4
I couldn't get the link to work
I assume gypsum board is the same as drywall/sheetrock. It comes in several different thickness's with 1/2" being the most common = what you probably have - check first to know for sure.
flirty1's Avatar
MI
08-18-07, 05:20 AM   #5
from the link
Regular Gypsum Board is a gypsum core board that is fire resistant and surfaced with paper on front/back and long edges. With its natural properties, it is durable yet easy to repair. In addition, gypsum wallboard’s fire resistance and sound control capabilities further demonstrate its desirability in building systems.
* Lightweight and easy to handle for speedy installations
* Lends itself to creative shaping in interior surfaces allowing for maximum design flexibility
* Durable yet easy to repair
* Takes virtually any decoration from paint, textures to wallpaper
* Surfacings on both faces and on the long edges are 100% recycled paper
* MFG Brand Name : ToughRock® Moisture-Guard®
* MFG Model # : 74
* MFG Part # : 74
mines 1/4 inch thick thats why its damaged not broken
marksr's Avatar
TN
08-18-07, 03:08 PM   #6
Are you in a mobile home? they usually have 1/4"
A patch would be better than filling/fixing what you have with joint compound and tape. I doubt you can find 1/4" at a big box store but any drywall supply house will have it.
Sarah Love's Avatar
08-18-07, 05:37 PM   #7
How do I plaster a wall
Should you need to re-plaster then you may find this website useful
Diy Video Tutorials
http://www.grahamvideos.co.uk
Hope this helps
Sarah Love
flirty1's Avatar
MI
08-18-07, 07:26 PM   #8
Posted By: marksr Are you in a mobile home? they usually have 1/4"
home depot had 4 foot by 8 feet sections of 1/4 inch drywall for around $8 a sheet and its HEAVY had to have it cut in half to fit in the minivan. the damaged area is 16 inchs by 17inchs.
flirty1's Avatar
MI
08-19-07, 10:04 PM   #9
ok I was going to the cut away the drywall about 1 inch above the hole and then cut it to the left and right until I get to the studs. then add a extra 2x4 to the side stud so I can screw the new drywall to it. then cut the new drywall sheet to fit the size of the hole with a circular saw.is that ok.
marksr's Avatar
TN
08-20-07, 04:39 AM   #10
It would be better to cut the drywall with an utility knife. Score the front side of the drywall, bend it and then cut the paper on the back side. A hand saw will also work. While drywall can be cut with a skil saw the dust created is enormous
flirty1's Avatar
MI
08-24-07, 10:49 PM   #11
Posted By: marksr It would be better to cut the drywall with an utility knife. Score the front side of the drywall, bend it and then cut the paper on the back side. A hand saw will also work. While drywall can be cut with a skil saw the dust created is enormous
can it be cut with a jigsaw and a shop vac hooked up as my jigsaw can by used with a bag
marksr's Avatar
TN
08-25-07, 04:45 AM   #12
I don't recall ever using a jig saw to cut drywall but it should do ok, with or without the dust collector.
flirty1's Avatar
MI
02-22-09, 02:01 AM   #13
ok still havn't fixed that yet. is a framing nailer a good tool for nailing new studs to the old for drywall. will get to it this spring.
marksr's Avatar
TN
02-22-09, 03:58 AM   #14
A framing nailer should work fine to attach the new 2xs although hammer and nail will work too. Whne adding nailers[using hammer], sometimes it's benificial to sink the nails into the nailer before setting it place.
jatco's Avatar
CANADA
02-22-09, 09:27 AM   #15
...or just screw your new studs to the original ones.
Less physical work and stronger..(presuming you have a drill - cordless or not).
flirty1's Avatar
MI
02-24-09, 03:02 AM   #16
i'll have to pick up a new multy speed drill as the current one has a broken trigger. so the only working drill i have is a single speed one.or i use a air ratchet with a screw driver bit.
jatco's Avatar
CANADA
02-24-09, 06:30 PM   #17
If you dont want to spend any money on tools.. just use your single speed drill to drive most of the screw in, then just tighten that up manually. You'll be good to go..!
flirty1's Avatar
MI
02-28-09, 03:13 AM   #18
Posted By: jatco If you dont want to spend any money on tools.. just use your single speed drill to drive most of the screw in, then just tighten that up manually. You'll be good to go..!
the single speed drill is like 1500 RPM. a 19V cordless multy speed drill is around 37 so will get that later.
flirty1's Avatar
MI
04-18-09, 05:30 PM   #19
its fixed. its not pretty but its done. just needs allot of sanding and painting. i did use drywall joint tape a wire mesh kind self sticking.I nailed to new studs to the existing studs to give me something to nail the drywall the too. I just nailed the drywall to the studs instead of using screws. used the framing nailer for both. now sense i got the wrong size drywall 1/4 instead of 1/2 inch i just cut both pieces together and doubled it up to make a 1/2 inch using a circular saw with a metal cut off wheel. Made ALLOT of dust good thing i cut it outside.
