Drywall ceiling circle cutters?
Smith Brother's Avatar
IN
12-23-07, 08:49 PM   #1
I believe I have seen in the box stores a adjustable circle cutter for drywall???
I need to cut in old work several drywall holes so as to install round plastic ceiling boxes. I need to cut a clean circle of 4 inches, and would such do the job? Any tips on using such is most welcome. I assume the cutter will be driven by a drill?
Thanks,
Dale
marksr's Avatar
TN
12-24-07, 03:59 AM   #2
Yes they are powered by a drill although I've never used one.
IMO it is better to use a 4" hole saw - it's easier and possibly neater
retired painter/contractor avid DIYer
coops28's Avatar
KS
12-24-07, 07:29 AM   #3
They also sell a cutout tool. It works like a compass with a point on one end and a sharp wheel on the other. Find your center, adjust your tool for the radius and score.
nap's Avatar
New Member
12-24-07, 08:00 AM   #4
and to finish coops direction:
cut with a jab saw.
If you can get a hole saw, that is the cleanest.
If you only have a few, the tool coops speaks of is good or if you are as cheap as I am, you may try to find a jar lid or other circle shaped thing to trace around and cut with a drywall saw.
never used the tool you speak of. Never seen it used either. I would take that as a recommendation as it is not anybody's tool of choice.
IN
12-24-07, 04:16 PM   #5
Thank you, FOR SURE.
I looked at the circle cutters and they say to score on BOTH sides of the drywall, so won't work for drywall already hanging.
I used a JAB SAW, after I made up a circle pattern and penciled in a good line.
Thanks again,
Dale
