Why bubble if i used mesh tape on drywall?
Received 0 Votes
My tools: Mesh Tape | compound | putty knife | sandpaper | utility knife
I have about 2 x 8 hole and I cleaned the area first using the sandpaper and utility knife.
I applied the mesh tape cover the 2 x 8 hole.
I applied the first coat compound on top of the mesh tape and I can see the mesh tape bubbling out (hump).
So, right now I stop because not sure what to do.
Should I put more compound to push it in the mesh?
Hi Mr_Helpme
You have to have some sort of backing in a hole that big. Something for the tape to adhere to and provide support.
Normally, you'd cut a piece of drywall the same thickness as what you have. Make it slightly smaller than the opening. Insert some backerboards (1 x 3, 1 x 4) into the hole, so that they overlap the edges. Screw the boards thru the existing drywall at the edges of the hole. Place your patch in the hole and screw thru it into the boards. Then tape and mud the seams and mud the screwheads.
I agree, a 2"x 8" hole is too big for tape alone. I'd either use the method discribed above or cut a 4"x 10" piece of drywall, remove the excess rock from the back side [leaving a solid piece slightly smaller than the hole] and use the excess paper on the front of the patch piece as your tape, then mud it in place.
