Help with patching..
Old 03-05-08, 01:50 PM
Ok.. I patched a hole and sand it with 220 grit.
I thought the patch was leveled with the wall.. so I started priming and paint the patch area.
Now this is the result after painting.
How should i correct this since it's only shallow?
Old 03-05-08, 04:08 PM
K
Patch again. Use a knife that spans the width of the depression. Use hard flat block behind your paper.
When I've hired drywallers, I always ask them to prime as well. You can't really know until the wall is one colour.
Old 03-05-08, 04:11 PM
Received 361 Votes on 318 Posts
Apply more j/c and when it's dry don't sand with your fingers, either use a sanding pole or even wrap sandpaper around a flat piece of wood. This will help you to sand it level with the wall
Old 03-05-08, 05:23 PM
E
It shrinks. And if you mix-in water with it, it even shrinks worse.
Old 03-05-08, 05:50 PM
nagra4s's Avatar
You Durabond easy sand. This product will shrink very little by the amount of water you put into it. A block sander as Mark said is best.
