Plastering question
daveyd's Avatar
04-05-08, 05:58 PM   #1
Plastering question
I have just finished drywalling my basement with mold resistent drywall, DensArmor Plus Paperless Drywall... http://www.gp.com/build/product.aspx?pid=4659
My question is, is plastering an option for this type of drywall or do I specifically need blueboard for plastering?
nagra4s's Avatar
IL
04-05-08, 08:44 PM   #2
I learned about this on this site. Never used it before. From what I see you need to finish this with joint compound using paper tape at the seams. You also need to skim coat the entire surface for sure!
http://forum.doityourself.com/search...archid=1537182
Top notch primer and finish coats, like a pro paint store Sherwin Williams or your local paint store.
daveyd's Avatar
04-06-08, 08:51 AM   #3
I found this on the DensArmor website..
Q:Can veneer plaster be applied over DensArmor PlusŪ paperless drywall?
A:Yes. Where DensArmor PlusŪ paperless drywall is to receive a veneer plaster, longer working or open time as well as longer drying times can be expected due to the product's superior moisture-resistance properties. Veneer plasters adhere well to DensArmor Plus panels. Always apply veneer plaster systems according to the manufacturer's recommendations.
I guess that answeres my question on whether or not plaster can be applied to it.
daveyd's Avatar
04-07-08, 10:02 AM   #4
Any drawbacks to plastering the DensArmor?
nagra4s's Avatar
IL
04-07-08, 06:28 PM   #5
Posted By: daveyd Any drawbacks to plastering the DensArmor?
90 days cure time before prime and paint. Primer should be oil based.
