All purpose vs. Lite compound
n0c7's Avatar
CANADA
04-06-08, 10:00 PM   #1
I've used all purpose/ready mixed compound from start to finish before but I recently heard about this lite compound stuff. Which coats should it be used for and what are the benefits?
marksr's Avatar
TN
04-07-08, 03:44 AM   #2
Lite weight joint compound sands a little easier than the all purpose. It can be used for any of the coats after the bed coat.
retired painter/contractor avid DIYer
n0c7's Avatar
CANADA
04-07-08, 07:30 AM   #3
Is it worth changing in your opinion?
marksr's Avatar
TN
04-07-08, 03:55 PM   #4
If I only had need for 1 bucket, I'd get the all purpose because it will hold [glue] the tape better. If your job is big enough for multiple buckets of mud, I'd switch to the lite weight after taping.
connie's Avatar
04-07-08, 04:00 PM   #5
I have problems with the lightweight, Mark...I put it on, I sand, it vanishes!
I do think it's a lot dustier than regular.
Connie
marksr's Avatar
TN
04-07-08, 04:39 PM   #6
Connie - I think you are using too much muscle
Personally, I'd rather apply an extra coat of mud than do a lot of sanding.
nagra4s's Avatar
IL
04-07-08, 06:31 PM   #7
I also have a problem with Lite JC, if you look at it.....it will nick. Very soft stuff. Also takes longer to dry. I admit though to using it for the final coat when I have a big job.
