wavy ceiling line
Old 04-18-08, 03:35 PM
D
wavy ceiling line
i would like to try to fix a "wavy line in my ceiling where the slant ceiling meets the flat..the drywall.framing..wasnt put up straight..and with 2 colors the wave is more noticeable. would i be able to repair it with joint compound and make a straight line? ty
Old 04-18-08, 03:52 PM
connie's Avatar
Yes, you can probably get a better line if you apply another coat of joint compound, but I swear that's why ceiling moldings were invented!
Here's an excellent tutorial, right here on our site!
Connie
Old 04-18-08, 04:18 PM
Received 870 Upvotes on 761 Posts
The wavy line is usually caused by either bad framing or a bad drywall hanging job [or a combination of the 2]
I'm sure you can fix it with j/c but it won't be an easy task. Personally when I see a bad angle like that I try to talk the customer into either painting wall and ceiling the same color or make the color change at the lower short wall.
Old 04-18-08, 05:33 PM
nagra4s's Avatar
Mark is right, keep the color the same on the slope as on the horizontal ceiling. This is what I recommend all the time to my customers on slopes and sofits..... keep the color the same. Only the large area horizontal surfaces I say keep ceiling white.
