removing old shower caulking
Old 03-28-00, 07:58 AM
Post
I need to recaulk around my standing shower stall. The old caulking is about 17 years old and has hardened up quite a bit. Short of using a sanding tool to grind or dig the old caulk out, how can I remove it? Is there a solvent I can use that will soften or dissolve the old stuff so I can put new in?
Old 04-10-00, 12:29 AM
Post
Marmy:
If you say that this stuff has "hardened up" then I presume it isn't silicone caulking we're talking about.
Go to the hardware store and buy a razor scraper in the paint department to cut out the biggest hunk of this caulking, and then use acetone to dissolve the rest.
K, G'Luck.
Trackbacks are On
Pingbacks are On
Refbacks are On
