how do i fix this ?
condo-owner's Avatar
IL
06-21-08, 07:38 AM   #1
how do i fix this ?
it is a little worse that the pics show. i am not looking for perfection. just something that doesn't jump out at you, and is not labor intensive. though, a lasting repare is desired.
thanx
marksr's Avatar
TN
06-21-08, 05:16 PM   #2
Looks like the corner bead is getting loose. You need to nail it tight, remove any loose joint compound and apply new j/c. Using a setting compound like durabond may hold up better although it isn't as user friendly as ready mix j/c.
retired painter/contractor avid DIYer
IL
06-22-08, 05:16 AM   #3
thanx. i figured that was what you were going to say.
IL
07-09-08, 07:32 PM   #4
the repair turned out good. thanx.
