patching plaster around an electrical box
Old 11-17-08, 06:20 AM
Greetings,
Doing a remodel in a house with plaster walls(I've never worked with plaster walls) and of course I tore up some edges around the electrical boxes. It's one of those things where after the cover plate is on that only a little bit of the tear or hole will be showing. Enough will be showing that it has to be fixed.
What would be the best way to go about this? I know from experience that just putting mud on may or may not work. I've done this on drywall and alot of time it just cracks because there is just a bunch of mud stuffed in a hole with not much to hold on to.
Also, can I use drywall mud or does it have to be plaster?
Side note- I have some misc. holes in the plaster that need repaired. What is the best way to repair them?
Thank you,
Ron
Old 11-17-08, 02:36 PM
Received 317 Votes on 281 Posts
Generally plaster can be repaired using a drywall setting compound like durabond. It's a little more forgiving than ready mix joint compound but it is a bear to sand. how big are the holes?
You could also use oversized plates/covers to hide the gaps next to the box.
Old 11-19-08, 06:15 AM
Some holes are from lag bolts that held the cabinets in. Other holes are more like a 'crater'. They are around an inch wide and flush with the plaster around the edge and go to about a 1/4-3/8" deep in the middle. I figured drywall compound should be fine.
The over sized cover plates still aren't big enough. There would still be just a very little bit of gap showing even with the bigger cover plates.
Thanks for the help...
Ron
Old 11-19-08, 07:08 AM
If you use ready mix joint compound you will need to also use tape. Durabond will be ok without tape providing it has enough surface to adhere to.
