Using Adhesive on Drywall
whitetiger97's Avatar
11-29-08, 04:20 PM   #1
Hello,
I am going to put up drywall over paneling in a double wide mobile home on a basement.
It is an older home and I believe the walls are constructed of 1x3's. So I have two questions.
1. Can I use construction adhesive to put up the drywall? The thought of trying to use screws and hit 1x3's is not looking easy.
2. If I do use adhesive, would you recommend 1/2 drywall or 3/8? The price differs is only .30cents a sheet. I was thinking that 1/2 would be stronger and easier to finish.
Any other recommendations are always appreciated.
Thanks,
Norm
marksr's Avatar
TN
11-29-08, 05:16 PM   #2
The exterior walls should be either 2x4 or 2x2. I've never seen a MH that had 1xs on the exterior walls. Interior walls are another story. I've seen 1x2, 1x4, and 2x2 on the interior walls - all in the same MH. The bottom stud wall plate is almost always a 1x. The common wall on a double wide is normally a 2x3. Generally they use what ever work best [for them] on the interior walls.... at least I think that is their SOP
I don't think there would be any finishing differences between the 3/8 and the 1/2 since you are installing it over paneling. I used to look at 3/8 as being cheap but now that I'm older [w/bad back] I like the fact that it isn't quite as heavy
Adhesive is almost always a plus but you still have to mechanically [screw/nail] secure the drywall to the wall - you just don't need to use as many.
retired painter/contractor avid DIYer
