Stymied by Stucco
Old 04-07-09, 11:17 AM
Stymied by Stucco
Holy 1982 - My basement is pure stucco, all walls, posts and ceilings, even inside of some of the closets, are dust grabbing stucco.
Aside from ripping it out, is there anything I can do with it? Someone I know suggested sanding it down and said this will leave a "textured" wall. I just don`t know if it`s true. I figured I would try it first in a closet but thought I would check here first.
Any suggestions at all would be appreciated. Thanks!
Old 04-07-09, 11:42 AM
Gunguy45's Avatar
Super Moderator
Is it real stucco or just a very rough coarse drywall compound/plaster textured finish?
I think I have seen this question before, and the recommendation was to scrape it with a broadknife to knock the worst off, then skim coat it with compond for a smoother finish. Sanding will create a ton of dust, but might work. How much work are you willing to put in? The materials wouldn't cost that much, but there would be a good amount of labor involved.
Pro's will be around soon...
Old 04-07-09, 02:12 PM
Ya, we need to know just what you have. Stucco is a masonary product applied over masonary or wire lath. Are the walls painted? Joint compound is a lot softer and is normally applied to drywall. Scraping and filling in would be the fix but we need to know what you have.
Trackbacks are On
Pingbacks are On
Refbacks are On
