Knockdown texture in a spray can....
Old 05-02-09, 06:02 PM
B
Have any of you had luck with getting knockdown texture by using the texture in an aerosol can?
I have used it a couple of times, and each time, the texture smears instead of knocking down. The directions say to wait for 30 seconds to 1 minute. Definitely not long enough to set up. I have waited 10 minutes before and I get a weird smear...kinda like rubbing vanilla pudding on a wall....but no knockdown.
Fortunately, these have been for small projects where the texture is mostly out of site. So I have not worried much about a smeared but smooth texture surrounded by knockdown.
But generally speaking...have any of you been successful with texture in a can?
Old 05-03-09, 05:28 AM
Received 821 Upvotes on 720 Posts
I'm not overly fond of the spray can textures [prefer hopper gun] but I can't imagine getting enough of a splatter out of a can to give much of a knockdown look. Do they have an adjustable or changable tip? You want the largest size.
Old 05-04-09, 03:05 PM
B
The nozzle does come with a twist knob that technically should adjust the splatter, but I usually cannot tell the difference between the settings. When I spray (no matter what the setting on the nozzle) I get a fair looking pattern on the wall, but it never quite sets up. It usually goes from being loose/watery, to suddenly being too dry to knockdown. I can't find a nice middle ground where it is firm enough to knockdown.
For the patches I have worked on, they have been mostly out of sight, so the poor texture is still better than the pre-patched wall. But I am leaning towards trying a different method next time.
Yet I would LOVE to figure out how to get the texture spray can to work....seriously, only a couple of seconds to spray on and then a couple of moments to knockdown...almost worth the aggravation.
Old 05-05-09, 06:21 AM
coops28's Avatar
those cans don't work!!! The big problem for me is whats inside. No seriously, whats inside??? Whatever it is is nothing like mud. Its more like fluffernutter.
For small patches I can take my clean up brush and do a good job stomping on mud and knocking it down. But I always set up my spray rig for bigger patches.
Old 05-06-09, 05:26 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I agree with coops28. Smaller areas, use a brush or roller to put up a "stomp", then after about 30 minutes LIGHTLY knock it down. It may be you are applying too much pressure or using too narrow a knife. Use no less than a 12" knife to do the knock down in the smaller areas. Keep an angle on the knife, dragging it across the material. Methods may vary, but I find it works fairly well.
Old 05-06-09, 01:04 PM
T
Received 48 Upvotes on 41 Posts
I use 20 minute or 40 minute mud depending on the size of the patch. I dip my dash brush into the mud and then flick the mud from the brush with my hand. If you don't have a dash brush use a whisk broom. Just as it sets knock it down. My patches are pretty near invisible to everyone but myself and the owner. I tell them that someone walking in off the street should not be able to find them and that is about as good as one can hope for.
When I am doing an orange peel or a little heavier spatter texture that is not knocked down I've had pretty good luck with the can texture. Not so for knockdown.
