Failing at patching knockdown texture
Old 05-11-09, 04:17 PM
So I'm an idiot and punched a whole in a wall one fine evening. Since then, I have learned my lesson by having lots of trouble matching up the texture when patching. Being the amateur I am, I first paid a "professional" to come and do it. I wanted it to look perfect and had no problem shelling out the cash for it. However, this guy turned out to be a joke. $70 and the texture was utter crap. I ended up sanding it down and trying to do it myself. After several tries, this is what I came up with:
Few feet back:
Up close:
Up close of an untouched area for comparison:
I don't think its terrible, but I wish it was better. I've been using
I've been using this:
I just can't seem to get a coarse enough texture using this spray can. The stuff just isn't thick enough.
So, any thoughts? Any other products I can try? I'm hesitant to try another "pro" with my last experience, but is this my only option for success?
Thanks for any help.
Old 05-11-09, 04:57 PM
I use 20 minute or 40 minute mud depending on the size of the patch. I dip my dash brush into the mud and then flick the mud from the brush with my hand. If you don't have a dash brush use a whisk broom. Just as it sets knock it down. My patches are pretty near invisible to everyone but myself and the owner. I tell them that someone walking in off the street should not be able to find them and that is about as good as one can hope for.
When I am doing an orange peel or a little heavier spatter texture that is not knocked down I've had pretty good luck with the can texture. Not so for knockdown.
Old 05-11-09, 06:30 PM
I saw you mentioned this technique in another thread. It seems like there would be a difficult learning curve with this (the type of thing that takes lots of practice to get right). I'm not going to lie, with no wall-patching experience prior to this, that technique sounds over my head.
Old 05-11-09, 10:40 PM
You might try spraying the knockdown, letting it dry then shaving off the points. I haven't done it this way but it might work.
