Primer old plaster before patching?
foothill's Avatar
CAL
06-04-09, 06:21 PM   #1
Its been recommended to me that I prime my old paster with a shellac-based or alkyd primer prior to patching with setting compound. Is this extra step and expense necessary?
GBR in WA's Avatar
WA
06-04-09, 06:43 PM   #2
Yes. Read this page and then click on "cracks" on the left boxes:
Getting Your Plaster Surface Ready For Repair
Be safe, G
foothill's Avatar
CAL
06-04-09, 08:31 PM   #3
The webpage reads, "...you may choose to brush on a coat of fast drying oil-based primer/stainkiller for extra security." So it is a judgment call I take it.
marksr's Avatar
TN
06-05-09, 03:54 AM   #4
What shape is the plaster in?
If there is any chalk/dust that can't be completely removed - use primer.
retired painter/contractor avid DIYer
foothill's Avatar
CAL
06-05-09, 08:16 AM   #5
marksr:
Thanks for the reply. The old plaster is tight and clean. The situation is that I'm removing 5/16" laminate wall panels and then scraping away the backer glue cauing me to lose chunks of plaster.
I think I'll continue to scrape away any loose stuff, dust with a whisk broom, mist the old plaster with water and then apply the new stuff. On any deep areas I'm embedding mesh tape.
coops28's Avatar
KS
06-05-09, 01:35 PM   #6
There is a product called plaster weld. You can get it at sherwin williams. You put it on the sandy areas of plaster and it makes it hard as a rock.
foothill's Avatar
CAL
06-05-09, 03:19 PM   #7
Thanks for the responses. I couldn't find plaster weld so I did picked up a 13 oz. spray can of shellac-based primer made by Zinnser at Home Depot. I'll spot prime any areas that are especially sandy and approach it that way.
