Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
Cornerbead around window casing. and cathedral ceiling???
Old 07-19-09, 08:39 PM
Hey i am drywalling the whole window casing no wood and i was wondering what to do where the two edges of cornerbead meat in each corner do i put a piece of tape over the edges and featherout or will the joint compound be thick enoough to hide the ends of the corner bead. and one more question i am doing a cathedral ceiling my problem is where the middle of the ceiling is lower than the butting edges to it in some spots i am going to be applying no coat 450 ultra flex to the off angles what should i do.thanks
Old 07-20-09, 03:06 PM
coops28's Avatar
on the inside (reveal) angle you would angle tape before putting bead on. On the outside you can cover the little square with in the corners with tape.
How much offset is your peak?? It's always best to get that as straight as possible before you tape. Pre fill with quick set. then apply your no coat.
