fixing tear in drywall
Old 09-01-09, 09:10 AM
Hello, I am repainting my kitchen and there are a couple of spots I need to fix first. They look like the top drywall layer is "peeled" off, almost like paper.How do I fix this?Thanks
Old 09-01-09, 10:01 AM
Depends.
If it is in a conspicuous spot (or subject to regular humidity) and it is a small patch, I would replace the drywall. Cut out a square, replace with same thickness square, then tape and mud.
If it's inconspicuous, or enormous, and not subject to regular humidity, I would skim coat. First, I would prime the area. Then skim coat with mud, feathering the edges with the intact wall. Then prime over that.
I've done this a few times, most notably on a bedroom that we inherited with layers of stone-aged border paper that ripped the drywall paper off. 3 years later, you can't tell, and no troubles.
Also, depending on how big the patch is, you could layer in either drywall paper tape, or scrape the rock off of a piece of scrap drywall and use its paper.
Old 09-01-09, 02:58 PM
Received 153 Votes on 136 Posts
No need to replace the paper but you do need to prime the exposed gypsum before applying joint compound. It's best to use a solvent based primer. The moisture in latex primers can cause the edges of the paper to peel some more
Old 09-07-09, 10:55 PM
Smile Drywall Repair Response
I have run into this situation with several bathrooms I have completed. Kilz works well on the drywall and I usually use a 20 or 45 minute set drywall compound to prevent bubbling.
