crack in wall
peterr's Avatar
MD
10-03-09, 03:07 PM   #1
crack in wall
Hello
There is a thin crackline from the top of the ceiling(cathedral) for about three feet down. Is it best to caulk it and wait, or cut a v and fill with spackle, or use fiberglass tape and mud it.
Thank you
marksr's Avatar
TN
10-03-09, 05:28 PM   #2
Is the crack out in the wall or does it run down the inside corner edge? If it's in the corner - caulk would be the easiest fix, should hold up well and not be noticable
Do you have plaster or drywall?
Generally joint compound is a better choice than spackling, and a setting compound [durabond, easysand] is better than j/c. Usually a taped joint will do the best. The sticky fiberglass tape has a poor record. If you do use it, it's best to use a setting compound.
retired painter/contractor avid DIYer
peterr's Avatar
MD
10-04-09, 08:48 AM   #3
crack
The crack is about four feet out in the wall and about three feet long.
I already caulked it and am planning to paint it soon.
I will see how it holds up and if there is a problem I will use the paper tape and a setting compound. I had forgotten about it so thanx a lot.
