Mending walls after electrician
CarolinaGrrl's Avatar
11-04-09, 07:52 AM   #1
Help! I am remodeling the kitchen. Yesterday the electrician cut big holes in the walls where the new cabinets will be installed. Although he put the sheetrock back in place, do I need to seal them up? Mud and/or tape? Have it replaced? Any suggestions?
marksr's Avatar
TN
11-04-09, 01:04 PM   #2
Welcome to the forums!
As long as the cabinets will cover those areas, there isn't any need to do anything else to them. If it makes you sleep better you can tape the joints - just be carefull that you don't build up the area with joint compound where it will affect how the cabinets mount.
retired painter/contractor avid DIYer
mgmine's Avatar
NY
11-05-09, 07:20 AM   #3
I would tape the holes, if not and they are on the outside wall then cold air will come through the seams.
