Do I need a corner bead on beam's tapered joint?
doodlehound's Avatar
02-03-10, 08:03 AM   #1
I have a beam that we put drywall on, and I am scratching my head over how to finish the bottom seam where the drywall on the side meets the one on the bottom. The other side of the beam has a butt joint, so I know it needs a corner bead. The side of the beam I am wondering about has 2 tapered edges and makes a really nice corner. Do I really need a corner bead? Can I just tape it with the mesh? I wish I didn't have to wrap the mesh around the corner, it's such a nice edge, but I guess I would have to. What I really would like to do is just fill it in with joint compound and not use any tape, but I think that would be asking for cracks later. I have a pic I can send if I am confusing, lol. Thanks for helping this newbie!
Laura
mickblock's Avatar
IN
02-03-10, 08:42 AM   #2
Outside corner bead helps form a nice corner shape, but they also cover the exposed edge of a panel and protect the corner.
But if I'm missing your point then ya might as well post your picture for everyone else!
Tolyn Ironhand's Avatar
MN
02-03-10, 09:52 AM   #3
I would still suggest putting corner bead on all corners. The factory finished tapered edge will not give a crisp corner that the corner bead will. It will also be easier to finish.
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
marksr's Avatar
TN
02-03-10, 01:31 PM   #4
I'm not sure I totally understand but all outside corners should have corner bead.
If we've misunderstood, provide a pic or two
http://forum.doityourself.com/electr...your-post.html
retired painter/contractor avid DIYer
stickshift's Avatar
WI
02-03-10, 04:05 PM   #5
Also, you mention mesh but it has been the experience of those here that paper tape works better than the mesh.
02-03-10, 04:06 PM   #6
OK, I learned how to attach a photo!
Here's a pic, that was easier than I thought. Sounds like I just need to suck it up and put on corner bead, though. It's not that I'm lazy, of course, just efficient with my time. ;-)
http://www.flickr.com/photos/[email protected]/?saved=1
mickblock's Avatar
IN
02-03-10, 05:12 PM   #7
Why do you hate cornerbeads? Because you have to blend in the ridge with compound? Well in this case you'll have the taper to blend to. Should look great!
sidenote - If you left it like that you would see the taper. You know? Not that it isn't a very handsome looking corner.
02-03-10, 06:38 PM   #8
Gonna do it! Thanks.
Posted By: mickblock Why do you hate cornerbeads? Because you have to blend in the ridge with compound? Well in this case you'll have the taper to blend to. Should look great!
I guess I don't like them because I haven't done many, and I have to fight with them. By the time I finish, I guess I will not be as intimidated, huh? Thanks for all the advice, everyone. Wish me luck.
