repairing of first-timer mistakes
Old 03-02-10, 12:25 PM
Question repairing of first-timer mistakes
we recently finished our basement, and unfortunately, as first time mudders, did not do a very good job mudding. Our choice of Semi-gloss paint makes the issues extra-obvious. We are going to change the finish on the paint, but were also wondering if we could re-mudd the seams over the paint and try again? Anyone have experience with this? I have seen suggestions for patches over paint, but I think I'm going to have to re-do ALL the seams...Should I re-tape? I have pics, but am not sure how to post them, as I don't have a url for them.
Old 03-02-10, 12:51 PM
Gunguy45's Avatar
Super Moderator
I hate drywall/sheetrock...mainly cause I don't do it enough to be any good...lol
No advise..but give it time....
As to pics..have you read this? http://forum.doityourself.com/electr...your-post.html
Old 03-02-10, 01:53 PM
You can apply mud over tape although it would be a good idea to scuff up the painted areas you intend to mud with 80-100 grit sandpaper.
If the tape was applied decently and lays fairly flat you can probably leave it on. If the tape has bubbles under it or is higher [sticks out] than wall - those areas may need to be redone.
Latex paint [especially enamel] doesn't sand very well but if you can fill in the low spots and spread the joints out over a wider area - that should work well
Don't forget to reprime the areas with new mud.
Old 03-02-10, 03:38 PM
Thx Marksr, I'm a little confused on your answer, if we're going to mud, we don't have to sand? I think the tape is fine. Actually, we found that to be the easiest part. We just didn't mud enough, especially where two of the tape sides of the drywall came together. I thought hubby was nuts when he said, "Just glob it on, it shrinks" Turns out he was right. The other area that is a little problematic is the corner beading. Can see the nail holes under the mud and paint.
Old 03-03-10, 04:11 AM
Joint compound sand easy but paint is harder to sand. Often it is preferable to apply j/c over the paint and then sand that thin layer of j/c. It might bring that part of the wall out further but if you float the j/c out over a wider area - most times it won't be noticeable.
It sounds like another coat or two of j/c will fix the problems. The neater you apply the j/c, the less you have to sand but you won't get completely away from sanding
sorry for the confusion
Old 03-03-10, 04:47 AM
Did you use a wide enough joint knife? Be sure you are using a 12" knife and be sure that the blade is facing the right direction. Usually the right direction is so that you don't see the name of the company on the handle. If unsure look down the edge of the blade and you will see a slight curve. The concave side should be facing the drywall. Don't keep going over the wet compound it will only make it worse. Be sure that the edges do not stick up if they do you will be in for a lot of sanding. Use a sanding pole and medium grit paper to knock it down.
Old 03-06-10, 08:00 PM
Thank you so much for the advice. We, did not, in fact, use a 12 inch knife on the joints...We will this time. I'll post when the fixes are done, and let you know how it goes...
