drywall
Old 04-12-10, 07:09 AM
D
drywall
what kind bead for drywall will run against paneling, so i can spackle right up to paneling? thanks
Old 04-12-10, 07:21 AM
Received 361 Votes on 318 Posts
I'm not sure I understand what you mean
Most any size drywall can be installed over paneling with 1/4" drywall being the thinnest. The majority of paneling is 1/8" thickness although some of the older better paneling might be 1/4' in thickness. A mud joint between wood and drywall is destined to crack.
Old 04-12-10, 08:19 AM
D
the drywall is perpendicular to paneling so drywall edge will but against paneling
Old 04-13-10, 07:14 AM
They make a u shaped edge that wraps around the drywall and protects the edge from chipping. This sounds like what you are trying to do. They carry it at Home Depot.
Old 04-13-10, 03:02 PM
coops28's Avatar
You need tear away bead or L- metal. I like tear away better. It only comes in vinyl so glue it on with spray glue.
