Drywall Finishing: Tape over seams not level
azzopf's Avatar
PA
05-23-10, 11:43 AM   #1
Is it okay to plaster over primer to patch, and then re-primer? I guess I've done a little of that, and it seems to dry hard and if there's a raised area and I have to sand off the primer, and plaster, is there an adherance problem with a mixed space, and then primering after finished again?
marksr's Avatar
TN
05-24-10, 05:08 AM   #2
Welcome to the forums!
There shouldn't be any adhesion issues with j/c over primer/paint although shiny coatings should be roughed up a little with sandpaper first.
You do mean joint compound and not plaster, right? I don't much a lot about using plaster
retired painter/contractor avid DIYer
stickshift's Avatar
WI
05-24-10, 12:05 PM   #3
No problem with compound over primer and then more primer but I would do all of the necessary sanding before re-priming
marksr's Avatar
TN
05-24-10, 02:08 PM   #4
I don't much a lot about using plaster"
should have read; "I don't know much about plaster"
apparently I don't know much about typing and the english language either
.....and yes, it's a LOT easier to sand the j/c than to sand thru any paint/primer that's applied over the j/c.
