Sheetrock Tips
Old 09-09-10, 06:58 PM
Sheetrock Tips
We're remodeling our bathroom and I need to replace some sheetrock on the wall above the tub, which I removed along with the tile, and another area where we removed a towel closet. I'm worried that the butt joint will be noticeable if it spans the full height of the wall so I was wondering if its a good idea to stagger the joints. Also, is there a way to recess butt joints slightly to make the joint easier to patch and make it less visible? If possible, should the butt joint fall on a stud? Since the section of sheetrock above the tub will be less then four feet, should I hang the sheet vertically with the tapered part towards the joint?
Also, I'm looking at a gypsum application guide (very helpful) which states that water-resistant gypsum board (green board) shall not be placed over any vapor barrier. Does this mean I need to remove the vapor barrier from the insulation on the exterior wall before installing the green board?
Old 09-10-10, 05:20 AM
You always want to stagger the butt joints!
If you can hang 1 sheet without any joints - that's the way to hang that board, otherwise the rock should be hung perpendicular to the framing.
IMO green board has out lived it's usefulness. It's not a good backer for tile and it doesn't always paint well. Regular drywall, primed and painted with a latex enamel should have all the moisture protection it needs.
Old 09-10-10, 01:05 PM
I plan on using Hardybacker for the tiled areas and regular sheetrock for the remainder of the bathroom.
Old 09-10-10, 02:38 PM
Section above tub less than 4 feet? Where? One of the end walls? What is next to it that less than 4 feet works, with no further explanation as to what is adjacent? Just curious.
After re-reading your post about the 4 feet business - do you mean that it is less than 4 feet up and down, or less than 4 feet side to side? If say you mean less than 4 feet up and down, I dont'tknow how it can be less than 4 feet off the top of a tub, as it be more than that up to any standard ceiling.
Old 09-10-10, 07:01 PM
Four feet wide, maybe 5 feet tall. I've actually decided to tear all the drywall out on that wall and replace the insulation and install an air gap (I think).
Trackbacks are On
Pingbacks are On
Refbacks are On
