On the fence of which way to go.
Tolyn Ironhand's Avatar
MN
12-31-10, 12:15 PM   #1
Building a wall to divide an already finished room (sheetrock all the way around). Walls are smooth, ceiling is knockdown so I want to avoid messing with the ceiling. This is a basement with floor trusses above that are spaced 19 3/16" OC.
My thoughts are either flat tape it where the wall meets the ceiling or use tear away and a small bead of paintable caulk. What would be the better option?
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
marksr's Avatar
TN
12-31-10, 12:43 PM   #2
I'd either flat tape and caulk or use a crown molding to hide the joint.
what's tear away?
retired painter/contractor avid DIYer
MN
01-01-11, 06:51 AM   #3
Tear away is a plastic piece (I can't think of a better word ) found with corner bead and that kind of stuff in the stores. It is kind of T shaped and you lay it flat on your wall where you have a piece of Sheetrock that has an exposed edge. It is used a lot in commercial where the rock meets the suspended ceiling tiles. You fill it in with mud, sand and then you pull off one leg of the T so it now looks like an L with it wrapping around the exposed edge of rock. Gives you a nice finished edge where the rock meets an already finished surface. But in my case I'm wondering if it is worth the extra time/expense when I can just flat tape it.
Here is a good picture: Tear Away Bead
marksr's Avatar
TN
01-01-11, 12:36 PM   #4
IMO it wouldn't be worth the extra trouble/expense. Flat tape works well although sometimes it will crack - the caulking addresses that.
MN
01-02-11, 11:53 AM   #5
That was kind of the way I was leaning anyway. Thanks!
