Wallpaper liner
Rainnelor's Avatar
NC
07-26-11, 05:53 PM   #1
Wallpaper liner
I removed wallpaper in my bathroom so I could paint. The wallpaper was stuck so firmly that at a number of places it pulled the paper off of the wallboard/sheetrock. I have been reading about wallpaper liner, and was wondering if anyone here could tell me how much a roll covers. Believe it or not...I have found it online in several places but it NEVER says how wide it is or how many running feet there are in a roll!
marksr's Avatar
TN
07-27-11, 04:02 AM   #2
Welcome to the forums!
I don't know much about wallpaper liners
Normally what's done when the drywall's paper face has been removed or compromised is to coat those areas with either a solvent based primer or Zinnser's Gardz. You can then safely skim coat those areas with joint compound to make all the damage disappear.
retired painter/contractor avid DIYer
annejay's Avatar
VA
08-11-11, 05:13 PM   #3
Same essential problem
I did the same thing removing wallpaper. The places are not deep but are showing the gray layer of the sheetrock. I do not want to put wallpaper back - I want to paint. How do I prepare these places for paint?
marksr's Avatar
TN
08-12-11, 04:45 AM   #4
Welcome to the forums annejay!
Anywhere the drywall paper is missing [raw gypsum exposed] needs to be coated with either a solvent based primer or Zinnser's Gardz. Once the primer is dry, apply joint compound as needed, sand, reprime [most any primer is ok this time] and then paint.
