Paper peeling away from Sheetrock ceiling
bryankloos's Avatar
CT
12-14-11, 04:11 PM   #1
Hey Guys,
I've got two ceilings where there are small sections of the paper peeling off the sheetrock. One in a bedroom and another in a dining room.
There are no water marks, so I don't suspect the problem is moisture related...
The house is 1940s cape.
That said, what can cause this, and what is the best way to fix the condition.
Thanks,
Bryan
marksr's Avatar
TN
12-15-11, 05:04 AM   #2
Not sure of the cause but to fix it you need to remove the loose paper, take a utility knife to cut the paper just past where it's loose [if you just pull it will keep coming off ] Then coat the bare gypsum with either an oil base primer or Zinnser's Gardz. Once the primer is dry apply a thin coat of joint compound.
retired painter/contractor avid DIYer
stickshift's Avatar
WI
12-15-11, 06:40 AM   #3
I can only think of moisture as a cause, never seen this otherwise except in cases where a mechanical reason was involved, like removing wallpaper.
Regardless, Mark gave you a good solution for fixing it. If you do and the problem goes away, I'd leave it at that.
coops28's Avatar
KS
12-15-11, 07:43 AM   #4
In the 1940's they plastered all houses then wallpapered every surface even the ceilings. So it's probably old wallpaper peeling off. Definitely scrape off everything you can. Then fill in will lightweight mud. If you do have plaster then you don't need to prime with gardz but if it is drywall then repair as stated above.
stickshift's Avatar
WI
12-15-11, 08:09 AM   #5
Nice, coops - I learned something here.
Thanks
