Durock-to-Sheetrock Transition
Old 12-20-11, 09:55 AM
What type of joint compound do I use to transition from Durock to regular sheetrock for shower walls? Durabond Setting-Type compound with alkali-resistant mesh tape? And do I use the same mesh tape for the other seams and patch with thinset?
Old 12-20-11, 11:50 AM
How you are going to finish the space? I assume you are using Durock and tile for the entire wet shower area and then need to transition to sheetrock outside the shower.
I usually do not tape the joint between cement board and gypsum board. I have always done it so I have tile on the cement board and make the transition to painted wall at the edge of the tile. I install the tile right to the edge or slightly over the edge of the cement board and then run a bead of caulk to finish the joint where it meets the drywall.
Old 12-20-11, 01:36 PM
Yes, that is correct. If there isn't any advantage to taping and mudding those end joints, then I would rather not.
Old 12-20-11, 02:34 PM
I don't tape that joint either. I try to put the joint where I get at least 1/4 of a tile overlap and then just caulk where the tile meets the drywall.
Old 12-21-11, 08:35 AM
Sounds good to me. That's what I'll do. Thanks.
