Factory edge/cut edge
Old 03-08-12, 05:09 AM
How do you tape a seam with a factory edge butted to a cut edge? Do you cut away some of the cut edge?
Thanks John
Old 03-08-12, 05:21 AM
Welcome to the forums John!
When possible it's best to avoid putting a factory beveled edge along a cut edge. The simplest fix would be to prefill the low side and then tape after it's dried.
Old 03-08-12, 05:56 AM
XSleeper's Avatar
You don't cut anything away. It's treated just like a butt joint. You can prefill but don't "have" to. Just smear the mud over the whole thing, bed the tape in it, wipe it down tight like you would a butt joint and then once that's dry, float it out as you would a butt joint. (wider than normal)
Welcome to the forums, BTW.
