Mesh showing through joint compound
Old 04-19-12, 10:35 AM
B
Before I start working on my master bath remodel, I've got a couple of holes to patch. I bought a kit that had an aluminum patch which I put on the wall and then covered with joint compound, which I then let dry for 24 hours. I sanded it and parts of the mesh were exposed. I put another coat on it, let it dry another day, and used a finer grit sanding block and the mesh is still exposed. Have I not put enough joint compound on it? What am I doing wrong? Would I be better off just to cut out the hole and put a drywall patch in there? Help!
Best
Rob
[IMG] Uploaded with ImageShack.us[/IMG]
Old 04-19-12, 10:56 AM
Received 97 Votes on 85 Posts
Can you feel the mesh or just see it?
If the former, then you need more mud. If the latter, primer and paint should suffice.
I suspect you will need more joint compound.
Old 04-19-12, 11:05 AM
B
On the lower right corner, you can see and feel it. On the remainder, you can just see it.
How thick should I apply the mud?
Old 04-19-12, 11:16 AM
Thin coats are best, maybe try a couple more thin coats before you sand again. Also, I would cover a much larger area so you can feather the mud out.
Old 04-19-12, 11:23 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
I'm kinda wondering about that leaf pattern I see near the bottom. Is that wall paper?
Old 04-19-12, 11:26 AM
Wallpaper?!?
Ugh, say it isn't so....
Old 04-19-12, 11:29 AM
B
Thanks, Mitch17, I'll put a couple more coats up.
Gunguy45, it's a mobile home, so the walls are covered with that "wonderful" vinyl paper that came with it, which we will cover with paint.
Best
Rob
Old 04-19-12, 11:34 AM
Tell me there are absolutely no adhesion issues with that paper.
Old 04-19-12, 11:39 AM
B
Doesn't seem to be. What I've put up so far has held to the wall fine. As for paint, we painted a wall a few years ago and it's held up just fine. Not my first choice for wall surfaces, but it's paid for.
Best
Rob
Old 04-19-12, 11:42 AM
Good. Paint over paper is generally a bad idea but I know that vinyl stuff in a MH is even worse to remove.
Old 04-19-12, 04:28 PM
Received 361 Votes on 318 Posts
You can't [or shouldn't] remove the factory wallpaper that's on MH walls. The printed vinyl takes the place of the regular paper on normal drywall - if you remove it your down to the gypsum
It's best to use a good primer when painting MH drywall.
Old 04-20-12, 08:09 AM
B
It's looking somewhat better this morning, but I've still had to touch up some spots. After this, I think it should look OK. Thanks for everyone's help.
Best
Rob
Old 04-21-12, 08:04 AM
B
Just wanted to post another photo that shows how much better it looks. It lays flat, the edges are smooth to the touch and a level put up against the wall shows virtually no "hump" in the center. Thanks for all the advice.
Best
Rob
