Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
What do I mix to get a sand/perlite texture
Old 03-08-13, 06:16 PM
What are the materials or what do I need to make the mix, I have the same project in a wall on a outside structure, thankyou
Separated from Reproducing sand/perlite texture.
Old 03-08-13, 09:51 PM
Nashkat1's Avatar
Welcome to the forums!
I've moved your post to its own thread so that the answers to your question won't get mixed in with those in the earlier thread. We have some pros here who should be along to help you out soon.
Old 03-09-13, 03:14 AM
I haven't applied sand texture in a long time but we used to just add the sand texture mix to the paint.
Are you sure what you have is sand texture and not sand finish stucco? Pics might be helpful - http://www.doityourself.com/forum/el...-pictures.html
Old 03-09-13, 03:37 AM
I've had good success with a mixture like this
1 box All Purpose joint compound : one gallon latex or acrylic paint : enough fine sand to make about 7 -8 gallons of material. Adjust the consistency with water to roll it on with a shaggy roller. Roll it all one direction then double back as soon as you get the area covered but going at right angles in the direction. ON ceilings go east - west then north -south or vice versa. On walls go up down then horizontal.
I use plaster sand run through a window screen or fine bagged sand. Finer sand = finer texture.
Oh, I just read this is an outside structure. Cancel all that.
What is the surface you want to cover? Wood? Masonite? Masonary?
Old 03-10-13, 10:44 PM
Re
This is a picture of what I'm looking for, and the walls are made out of concrete, I don't think I'll need sand whatsoever , but I want it to give me the same look as the picture, thank y'all
Old 03-11-13, 05:22 AM
Is the texture real abrasive if you drag your hand across it? If so, it's probably a sand finish stucco, if not, it might be a texture paint. Are your walls poured concrete or concrete block?
Old 03-11-13, 10:10 AM
You need fine sand. Is the wall painted already? Is the concrete new? Blocks?
If the wall is not painted you can use a Portland cement mixture. Don't try to invent your own when there are many proven products available. If it is painted already the add sand to paint. Experiment on the ratio. Yes if you want you can use perlite in lieu of sand. Your picture looks like a very fine sprayed or rolled finely aggregated material -- maybe in the paint or maybe in the texture material.
