Glue between drywall pieces?
Old 03-13-13, 03:01 AM
BGC
BGC is offline
I'm patching 32" x 32" and 32" x 16" sections of drywall. The existing wall thickness requires 5/8" plus 1/4" drywall. Is there a glue that I should use between the two pieces of drywall? If so, what type? I have considered but, will not use shims between the studs and 5.8" drywall.
Old 03-13-13, 03:09 AM
chandler's Avatar
You can use almost any construction adhesive, but one made specifically for drywall may be more viscous than what we use for framing and decking. Use longer screws, too so they will penetrate the studs behind the patches, as standard 1 5/8 screws will be marginal at best. Go for 2".
Old 03-13-13, 05:40 AM
I don't see any reason to glue the 2 sheets together. Once screwed, taped and finished - it ain't going anywhere.
