Spackle, Plaster or Joint Compound?
Old 03-29-13, 06:58 PM
Hi All
I am confused as to which is the best to patch up these two walls here. I don't need the best or long lasting solution, just the one that will work and make it look like an even surface.
What should I apply before painting over? Spackle? Plaster? Joint Compound?
Thanks
Old 03-29-13, 09:34 PM
It appears (correct me if I'm wrong) that the problem exists in the window jamb sheet rock. Why not tear it out and replace with new jamb casing? What is causing the problem??? That seems to be the bigger issue.
Old 03-29-13, 09:42 PM
I just need to patch it up, the bigger problem isn't mine to worry. Can you suggest? I think I am going to go with plaster? It seems to be the same material that is there right now.
Thanks
Old 03-29-13, 10:11 PM
One additional concern... Is the black stuff that I see at the joint, near the sill, mold??? If so, patching it up will not solve the problem
Old 03-30-13, 05:38 AM
I'd scrape off all the loose and then apply a coat or two of a setting compound like Durabond. If after scraping you find what remains to be chalky you'll need to prime it first or mist some water on it so the mud will adhere.
This looks like a bath rm application. Priming the window return and applying a latex enamel for the top coat will go a long ways towards preventing a reoccurance.
Old 03-30-13, 05:51 AM
Is this a window inside a shower?
Old 03-30-13, 09:52 AM
Why are you only looking to patch this up and not actually fix it?
Old 03-30-13, 09:57 AM
Mitch, if the damage is from the shower, patching and painting with enamel should fix it for the most part although tile on the return would be better. If the moisture is coming from the outside, the damage can return. Might be as simple as caulking the window on the exterior.
Old 03-30-13, 10:05 AM
Mark - you could be right but the line, "the bigger problem isn't mine to worry" has me wondering. Could be a perfectly good explanation.
