Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
How to remove plaster veneer from plaster walls?
Old 11-04-13, 02:38 PM
R
Background: Condo built in 1965 in south Florida.
I have multiple closets in my condo that has the wall surface cracking and blistering. From doing research it looks like I have plaster walls with a plaster veneer.... please correct me if I am wrong (see attached pictures).
I am trying to remove the surface to repair the cracks and repaint, but I need your advice.
1. How can I remove this surface easier? I am scraping but it is becoming very difficult and time consuming and I have multiple closets in the pictured condition.
2. Once I remove this surface is it okay to primer and paint straight onto the plaster? Or should I instead apply a new plaster veneer? If I try to primer the plaster, how much attention do I have to put into removing the dust that is embedded in the walls?
Any help or advice is greatly appreciated.
My current plan is to manually scrape it off, then use the wire brush along with a damp sponge to clean the walls. Then use a double coat of primer/sealer before painting.
Tell me if this is a good plan or not. If shouldn't worry about getting it all off since it is a closet, or what you would do. Thanks.
Old 11-05-13, 02:56 AM
Received 398 Votes on 354 Posts
Welcome to the forums!
You might be able to get a sound paint job by just cleaning up and priming the loose plaster but it won't look all that nice. It would be better to reapply the plaster, trying to mimic the texture so once painted - you'll never know there was an issue. I don't have any experience with plaster products so I generally use a setting compound like durabond instead when repairing plaster. With such a large area I might consider using regular joint compound as it has a longer work time and is more forgiving. Durabond dries hard like plaster, j/c dries to a softer finish.
Hopefully our plaster pro will have time to chime in later
