Hairline cracks around the door
Old 01-13-14, 06:48 AM
Hello everyone,
I noticed some hairline cracks around my master bath door. I do have some other cracks on other doors/windows, but mostly are along the seams. This set of cracks puzzles me a lot. I attached one pic here. Thanks.
Old 01-13-14, 07:48 AM
Very common to see cracks there around windows and doors caused by settling, drywall installed wrong or shrink swell soils.
About all you can do is use paper tape to patch.
Old 01-13-14, 08:18 AM
Thanks joecaption1.
I do have other cracks right above door/window and straight up, so it is more than likely on the seam. However these cracks are in 45 degree angle, multiple in a small area. Even they are just hairline, I don't know if there are any structural concerns behind it.
Old 01-13-14, 10:21 AM
Received 139 Votes on 124 Posts
More than likely it's a settlement crack, how old is hour house?
Old 01-13-14, 11:19 AM
Thanks Mark. It is 6 yr old house. Sorry for poor quality pic. Actually there are 4 cracks in the pic. Under the major one, there are two. The immediately below one is actually connected with the major one by another crack. All fine hairline cracks though.
Old 01-13-14, 02:45 PM
I wouldn't be overly concerned with them. It's normal for the wood framing to shrink some along with possible settlement. As long as the cracks don't grow or come back [if your repair them] there shouldn't be any concern.
Old 01-13-14, 06:09 PM
Hi Mark, Thanks so much. I probably wait a little bit.
Old 01-13-14, 06:46 PM
XSleeper's Avatar
Received 241 Votes on 222 Posts
They may have come from the trim carpenters beating on the drywall before they installed the casing. If the drywall is sticking out a little too far they will sometimes beat the drywall down with their hammer so that the casing (trim) lays flat. They may have been tiny cracks that are just getting a little more obvious now as the others mentioned.
Are these cracks on the same side of the door as the hinges? Or are they on the side of the door with the knob? The cracks could also be developing if the door is being slammed shut quite hard.... like by an angry youngster. (or wife).
Old 01-14-14, 08:09 AM
It is on the hinge side. My boys have been pretty gentle on these doors. That's only good thing.
