Patch from leak
petergriffen1's Avatar
NH
02-22-14, 06:05 PM   #1
Patch from leak
Leak is 99% fix will be taken care of in spring. Wide doesn't like my patch until then. So my plan is to cut the drywall to the size for now and finish in spring once leak is 100%.
Any way I should cut this to make it look better, it goes all the way to in top of the window sill. Never really patch and this doesn't look easy. Name:  image.jpg
Size:  33.2 KBName:  image.jpg
joecaption1's Avatar
VA
02-22-14, 07:17 PM   #2
Casing needs to come off the door.
All those crooked cuts need to be redone so there straight.
Easiest way is to just cut along side the stud or rafter and add a 2 X 4 to have something to screw the drywall to.
Install the ceiling first.
NH
02-23-14, 03:45 AM   #3
Should I use one piece for the bottom as it has to go above the window casing? Or should one go there and one to the left of it.
marksr's Avatar
TN
02-23-14, 04:10 AM   #4
You can use as many or few pieces as you want, more joints just means more taping/finishing. Extra joints at a door have a greater likelihood of cracking but shouldn't be an issue at a window.
What needs to be done to stop the leak 100%?
retired painter/contractor avid DIYer
NH
02-23-14, 05:05 AM   #5
I put tar on some of the seams where the shingles had been worn away by the extra water off the dormer. But I had one time when it leaked after I did this but for the past 6 months nothing. Plan is a new roof.
NH
02-23-14, 05:08 AM   #6
I was covering my bases with the tar
marksr's Avatar
TN
02-23-14, 05:11 AM   #7
Since it only leaked once in 6 months and you intend to reroof when the weather gets better, I'd be inclined to finish the drywall work .... should make mama happy and your life easier
VA
02-23-14, 05:30 AM   #8
Make the wall patch all one piece.
NH
02-23-14, 07:21 AM   #9
Any reason to not use the mold resistant drywall?
marksr's Avatar
TN
02-23-14, 09:43 AM   #10
You can use most any drywall as long as the thickness is the same as the existing. I usually use whatever I have on hand or is readily available
