Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Patching and Plastering
Reload this Page >
Repairing torn drywall paper- how do I fix this? And spackle vs joint compound?
Old 07-25-14, 01:17 PM
Exclamation Repairing torn drywall paper- how do I fix this? And spackle vs joint compound?
Hi P&P Forums,
I'm re-doing my bathroom, and tried to remove some caulking. But since it's a cheap, shoebox condo the drywall ripped in the process:
What's the best way to repair these rips? I found this Youtube video, but I'm not sure if it's the proper way to go about doing this.
Also, should I be using joint compound for this fix, or spackle?
Old 07-25-14, 01:50 PM
Received 98 Votes on 86 Posts
Remove all the loose paper, prime the exposed gypsum with Zinnser Gardz (or an oil based primer), smooth with joint compound, prime and paint.
Old 07-25-14, 03:16 PM
Received 384 Votes on 340 Posts
Spackling is ok for small areas but you can't thin it down and use it for texture like you can with joint compound. I rarely use spackle because I always have j/c on hand.
Old 07-25-14, 04:27 PM
C
Received 1 Vote on 1 Post
Spackle is actually a finer grain material than jc. It would be fine here if you already have it and want to use it.
