Hole in Ceiling
Old 08-16-14, 07:26 AM
Hole in Ceiling
I have a hole in the ceiling of the bathroom around the shower cord. Any advice on how I can repair this hole?
Old 08-16-14, 07:53 AM
Welcome to the forums.
I'm at a loss. What do you use that for in a shower ?
Old 08-16-14, 08:03 AM
It is just outside shower cubicle in the bathroom. It is used to turn on the hot water for the shower.
Old 08-16-14, 08:06 AM
I'm guessing your located in the UK. I've never seen that type of setup for water in the States.
It looks like you would need to remove that fitting and install a plate behind it. That would require drilling holes in the plate.
Can you leave a link to what that unit looks like not installed.... like maybe a manufacturers link.
Old 08-16-14, 08:13 AM
IF the unit/switch is mounted solidly, you might get by with flat taping the gap. Basically you'd smear a thin layer of joint compound on the ceiling around the hole then press/smooth a piece of drywall tape on to it, let dry, apply another coat of j/c, repeat if necessary, sand, remove dust, prime and paint.
