Door to doorless: drywall repair or replace
jdmorman's Avatar
NJ
09-03-14, 05:46 PM   #1
I would like to replace a door with a doorless entry by just drywalling around the studded opening. I removed the casing and door jamb, but in the process discovered that the drywall is crumbling and cracked in many places along the wall (maybe I caused this when removing the casing?) Anyway, can this be repaired, or must the drywall be replaced before I can put on corner bead, etc?
Name:  Photo on 9-3-14 at 8.31 PM.jpg
Name:  Photo on 9-3-14 at 8.32 PM.jpg
Name:  Photo on 9-3-14 at 8.32 PM #2.jpg
chandler's Avatar
GA
09-03-14, 05:56 PM   #2
Just apply sheetrock to the open edge and corner beads. You can make the boogers go away with joint compound.
marksr's Avatar
TN
09-04-14, 03:49 AM   #3
The corner bead should hide most of the damage and as Larry said, the rest can be fixed with j/c.
retired painter/contractor avid DIYer
