How to fill 1/2" and 5/8" holes in drywall ?
JimMcC's Avatar
WI
09-24-14, 11:24 PM   #1
What patching material should I use? I have lightweight spackle, but that won't work, will it? How do I keep the material from falling out of the hole? Thanks.
chandler's Avatar
GA
09-25-14, 03:19 AM   #2
Spackle is fine for your small holes. Just remember spackle is very difficult to sand smooth, so using it on larger areas could have its downside.
Pilot Dane's Avatar
NC
09-25-14, 05:00 AM   #3
Spackle or they make special mud or patching compound to do exactly what you want. Your holes are getting a bit big but you should be able to use a putty knife to fill the hole. Don't worry too much if you can't do it in one shot. Let the first bit dry and apply a second cote then sand it smooth and re-paint.
marksr's Avatar
TN
09-25-14, 05:02 AM   #4
Are you using spackling or joint compound?
Holes that size are border line on being able to patch with mud alone, any bigger you'd need to use tape. To patch alone you'll need to apply multiple coats of mud.
retired painter/contractor avid DIYer
JimMcC's Avatar
WI
09-25-14, 05:47 PM   #5
I have Red Devil lightweight spackle
marksr's Avatar
TN
09-26-14, 04:03 AM   #6
Spackling is formulated for small thin repairs. It may do ok but it will take multiple coats.
