Repairing plaster
Spunky424's Avatar
NY
12-16-14, 04:35 PM   #1
Repairing plaster
So I removed the wall paper in my entrance way to find this cracked plaster above my door. How would I go about repairing this section? I can feel cold air coming in from that spot that's exposed. Name:  image.jpg
Size:  22.7 KBName:  image.jpg
Size:  23.7 KB could I use spackle to repair? any help is appreciated.
tightcoat's Avatar
CAL
12-16-14, 05:31 PM   #2
Use some setting type drywall joint compound. Mask the picture mold and the door casing. Buy or make a tool that just fits between the two piecs of wood. Press the mud into all the voids then smooth it off.
Oh, one more thing clean out whatever is still there but loose.
marksr's Avatar
TN
12-17-14, 03:03 AM   #3
Not sure if you can buy a knife that narrow, I'd grind down the side of a cheap putty knife so it would fit between the moldings. You could just caulk the crack above the framing to stop the air flow if you don't have time to patch the plaster.
retired painter/contractor avid DIYer
czizzi's Avatar
VA
12-17-14, 03:19 AM   #4
Look to brick point tucking tools to find something that will work to fit into the area you have to work with. I have one for just these specific reason. Can be found near the brick trowels at the box stores.
Marshalltown 3/8 in. Tuck Pointer-TPSG38-HD - The Home Depot
Spunky424's Avatar
NY
12-18-14, 05:52 AM   #5
thanks for the advice i went to homedepot and picked this type of compound up:
Search Results for setting type compound at The Home Depot
hopefully this is the right one. i was planning on removing the trim moulding around the door because i think the plaster behind it is also cracking. repair the whole section and then put the moulding back on.
marksr's Avatar
TN
12-18-14, 07:07 AM   #6
The easy sand should work well. Remember to only mix up what you can use before it sets up. Any leftover mixed mud needs to be thrown out [it can dry rock hard in your bucket or mud pan] If any of the exposed edges of the plaster are dusty [and the dust can't be wiped off] it is usually a good idea to prime those areas first.
I've never applied mud directly over wood like that before but no bigger than the area is it shouldn't be a problem. If further scraping reveals a big hole, using a scarp piece of drywall makes a good substrate to apply the setting compound to.
Spunky424's Avatar
NY
12-18-14, 09:47 AM   #7
sorry bout that i linked to the wrong website: here it is:
SHEETROCK Brand 4.3 lb. Easy Sand 5 Lightweight Setting-Type Joint Compound-384151060 - The Home Depot
got the smaller bag since i didnt need so much.
marksr's Avatar
TN
12-18-14, 10:05 AM   #8
All the easy sand is pretty much the same except for the work time. What you bought will have a short work time but that also means it can be sanded or recoated sooner than a setting compound with a longer work time.
