How to apply door bumper over existing hole?
Received 0 Votes
I've got a small hole knocked in the wall by a door handle. I'd like to cover the hole and prevent further damage at the same time, by installing a wall door stop:
[ATTACH=CONFIG]52896[/ATTACH]
But this door stop mounts through a single screw in the center, which of course will be right where the hole is. Should I clean out and replaster the hole before installing the screw? Or do something else entirely (I don't know — glue it on maybe)?
Thanks for any advice.
Yeah, I don't think there would be anything wrong with plastering it in... then putting in he supplied anchor. Although those kind of repairs will sometimes want to break out again. You could also forget about the supplied anchor and just get a toggle bolt and a 3" screw. Put the toggle bolt on the door stop, drill out the damaged area, insert the toggle bolt, pushing it all the way in, and then pull the door stopper toward you so that the toggle bolt catches on the back side of the wall... and then just tighten the screw.
That will look like poop.
Fix the wall and install a stop on the top hinge or a threaded one that mounts to the base board.
Look at the top row of items.
Door Stops - Door Accessories - The Home Depot
They make self adhesive flat ones that have a sort of textured finish and can be painted. They look a bit commercial, but they do the job.
This rental I'm in has those as well as baseboard mounted stops. I don't like the hinge stops as they seem to loosen and can damage the casing if really shoved.
