Mud and drywall tape used on cement board
Old 03-21-16, 08:44 AM
Hello!
The handyman who installed the cement board around my bathtub
used mud and drywall mesh tape.
I found out this is not correct after he was finished.
The guide reads "Joining Fill joints with latex-fortified mortar or Type 1 organic adhesive and immediately embed alkali resistant, fiberglass mesh joint tape.
No tiles on yet. I was thinking just to paint over everything with a sealer before the tiles are put on.
Should I try to peal the mesh and mud off and redo the edges and corners? ...or just leave it and paint with a sealer?
Old 03-21-16, 10:02 AM
Received 427 Votes on 382 Posts
If he used regular ready mix j/c you should be able to get it wet, dissolve most of the mud and remove it.
Old 03-21-16, 10:10 AM
XSleeper's Avatar
Received 990 Votes on 901 Posts
If he used setting compound (hot mud) and alkalai resistant mesh, its fine.
Old 03-22-16, 07:27 AM
Hot Mud - not
Hi XSleeper
Thank you for replying -
I looked up what Hot Mud is and the handyman
who did the cement board used a ready mix, not a powder - I
believe the Hot Mud is mixed- I had to look up what Hot Mud is.
So he didn't use that.
Old 03-22-16, 07:31 AM
Water is ...well ...awesome
Hi markrs,
I am going to try to dissolve it with water
and see if that works.
Many thanks for a method to try.
Old 03-22-16, 07:57 AM
Hot mud or setting compound comes in powder, the 2 most common brands are Durabond and EasySand. They are not water soluble. Mud that comes in a bucket [premixed] is water soluble.
Old 03-22-16, 08:02 AM
It is nice to get clear information thanks again
Old 03-22-16, 02:34 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
If you are dissolving the drywall mud, use thinset and the correct tape on any joints between boards and in the corners. Thinset mixed from a powder, not a ready mixed thinset. To clarify, it's OK to blend the edges of the cement board where it abuts to drywall with joint compound and regular/mesh tape. This is usually where the bullnose tile will overlap onto the drywall.
